I Need Flash/Lectora Help
Hi Ben,It depends on how the graphing object is built. What is being passed from Lectora, and how often? Is it something that is done all on one page, or does the graph change over the course? I'm sure you are using Lectora 2007 so the flash command to set variables is what you will want to use - but it really comes down to how things are set up on the flash side to make sure it will work. If you can give me some more info maybe I can be of more help.-Mark
