Drag and Drop Help
March 12, 2006 12:00 AM
Hi Ben,Which version of Lectora are you using?I am using the Professional Publishing Suite 2006 and it has the option to add a drop point distractor as well as a drag item distractor.I'm not sure how you will do it otherwise.Andy
