Purpose of Tips and Tricks Forum
February 20, 2009 12:00 AM
Hi, folks -Just a reminder that the Tips and Tricks forum is meant to be used as a place for folks to share with others tips/tricks that they've found/figured out. If you want to post a message asking for help in using Lectora, then the General Lectora Discussion forum is the best place to post your message. (If you have questions about using CourseMill, then use the General CourseMill Discussion forum, instead.)Hope this helps clarify things!Laura
