Publishing Audio with non-SWF Controller
So, I'm trying to use Lectora as a "wrapper" to publish an audio file that needs to be playable on iPads and Windows computers. When I publish the "course," the controller it provides is a SWF controller. I'm trying to use SharePoint to deploy the finished product (don't ask....), but SharePoint won't let me upload SWF files (and I think iPads can't use a SWF file anyway). Is there a way to substitute the SWF controller with one that SharePoint will accept and an iPad will play?
Just ignore the SWF. You can even delete it before uploading. When you launch the course on an iPad, it won't load anyway, and the audio will be played via a HTML element.
Hi Laura,
I have the same problem with SWF on Ipad.
Did you solve it?
Well, kinda sorta. I solved the problem of creating iPad-friendly audiocasts, but I didn't use Lectora to do it.
One solution I found was to use YouTube (convert the audio file to a video file format, then uploading it to a custom YouTube account/channel) and another one, for more secure stuff, involved using Adobe Presenter to publish the audio to our internal Adobe server.
Hope his helps! :)
