Problem with Text Wrap in 2008?
September 24, 2008 12:00 AM
Okay, now I have a simple page with a plain text block and a graphic on the right side of it and, although I've set the text block to wrap around the graphic, it's simply not doing it at all. I've checked that the graphic is layered above the text block, so I know that's not the problem. I'm still using Lectora v8.Ben - I know that earlier you mentioned that you have had problems with this when the graphic was on the right. Did you ever report this problem to Trivantis? If so, did they give you any kind of response? Also, have you seen any difference in v9?It's just so frustrating, because this feature worked fine in 2007 -- I remember being quite excited when they it for that release. I hate to having to go back to making manual wraps-arounds using multiple text boxes...
