Problem with Text Wrap in 2008?
September 24, 2008 12:00 AM
Make sure you graphic is in front of the text box. Make sure you layer it that way. That is my only suggestion. I have not tried it in V9. It is also a bit funky on bullets when the object is on the left.Make sure you graphic is in front of the text box. Make sure you layer it that way. That is my only suggestion. I have not tried it in V9. It is also a bit funky on bullets when the object is on the left.
