Keystroke and Questions...
January 23, 2007 12:00 AM
It does make sense. Your actions do NOT affect or select the radio buttons. They set Question_0001 value to "True" or "False". Then when the page is reloaded(refreshed) you will see the button checked. I think there is some other way to do this but not sure. Oh, you can see this work without the JavaScript. Just set the question variable on the page, then Next page, then Prev page. There you go! The button shows selected. If you need a non-html solution, this is how you do it - go to some other (blank) page and that page does an immediate Back.
