Buttons/Text Boxes/Images not selectable
Tanja: "If you want to make a piece of text clickable, it should be turned into a hyperlink, or a transparent button should be placed on top of the text."But then you said that we can't use button objects because of the issue with JAWS.And what about clickable images? My main issue is that it seems like no Lectora actions for links EXCEPT hyperlinked text are usable when using JAWS (without using any funky keystrokes)- correct? Or am I missing something?Edited By: CDC_Joe on 2007-10-23 9:38:10
