Print to PDF crashes entire system
JoeDo you also have the updated and current acrobat reader installed? Maybe there is a simple issue there... are you able to install that, in addition to your Pro version just to make sure.Sounds like there is a driver or stack issue when this is occuring. I'd install the free current reader. Test. If no go, then reinstall the Pro version and test.This has got to be simple...Can we assume too that you have no issues printing PDF docs outside calls from Lectora? (you never actually say you are printing from Lectora, so I am assuming that).Lastly, what gives, wern't you the old CDCJOE? Now you are getting all formal on us... sheesh!
