Print to PDF crashes entire system
June 24, 2008 12:00 AM
When I print to PDF, the document fails to print sometimes, but doesn't lock up my computer. But most of the time it works fine. I am using Adobe Acrobat 6.0 Standard. I dont know if this would cause a huge difference.When I print to PDF, the document fails to print sometimes, but doesn't lock up my computer. But most of the time it works fine. I am using Adobe Acrobat 6.0 Standard. I dont know if this would cause a huge difference.
