List of problems with Lectora 2006
March 3, 2006 12:00 AM
tekprof wrote:
even when I write my own html directly) that contains an apostrophe and send it to a cgi program that contains the variable in an sql statement, all hell will break loose. That is because it sees the apostrophe as a terminator of sorts as part of the sql. The way I deal with this is to change the apostrophe to something else (I typically use a tilda) after the request action in the cgi but before I submit to the database. When I do that I have no problems with apostrophes. I've had the apostrophe problem before in a lectora file which was juts html and no cgi usage.The other day i had someone come to me with problem 4. I ungrouped a list of actions and it was fine again. I'm telling you, there are problems with grouping. I know this.Edited By: RupertAb on 2006-4-27 14:5:17
