List of problems with Lectora 2006
6)On point 6, I have now found out the solution from this board. It is a very simple solution. If you read above you will see that point 6 is what I consider the worst problem. The cookie can be filled very easily and your variables subsequently nulled.The solution?Simply checking that checkbox to include the Titlemgr frame when compiling.For the last two years I've been complaining to support@trivantis.com about the problem of variables being overwritten and the amount of inconvenience it is to "slim" things to fit into the cookie. Now I'm dumbfounded that they didn't tell me this simple solution.
