Info Cards Positioning/Formatting
July 16, 2024 2:38 PM
I've just opened CVR after not needing to use for quite a few months and am editing an old CVR scene. The formatting of info card objects is all over the place. I add an item, place in a fixed position group and the font size is tiny. Adjusting the small/medium/large doesn't make any difference. I move it and it repositions all the other grouped items out of place after dropping, its really quite unusable. I'd be better off inserting a graphic with all the text flattened inside.
Discussion (1)
Moving a text object in a fixed position group causing an issue with placement of other objects in the group was an issue that was found and fixed in the latest release. Thanks for pointing that out
