Transition out not working with audio event triggers
May 18, 2010 12:00 AM
Hello all,
I am having one of those days where Lectora is out to get me!
I am using .fla audio files with event triggers. There are about a dozen event triggers on a single page and to eliminate a lot of extra actions, I decided to use the "Transition Out" option to get rid of the objects shown by each event trigger.
The problem is that it appears the "Transition Out" is ignored when I "Show" (or "Toggle Visibility State") the object by an event trigger.
SOLUTION (UPDATE):
In order to hide the object, I was successful by adding a separate action which does the hiding.
Moving on....
More From sconnell
How do I display text with a variable in a 'Standard Message Window"?
April 29, 2010 Reply 0 UpvotesLectora X (Pro Suite) VS Adobe Captivate 4 for software simulation?
January 26, 2010 Reply 0 Upvotes
