Serious problems with Quiz - Anyone encountered these issues?
May 3, 2010 12:00 AM
Hello folks,
I am encountering three problems with the quiz section of my course.
NOTE: This email was edited to add new information from the earlier message.
1. Running Quiz - Browser incompatibilities?
On both the Mac and Windows, the Chrome and Safari browsers fail
to start the Quiz section (A002) of the lesson.
The Quiz window will open and simply state... "Loading... [lesson
name]...please wait." The background window will state, "Running
Courseware. Do not close this window...."
It is important to note that the Lesson Section (A001) works with all
Tested browsers.
Summary:
Works with: IE8, Firefox
Fails with: Chrome, Safari
2. The Quiz end button fails - Browser incompatibilities?
The last question "Submit Answer" button sends:
On Click Action:
Submit/Process Test/Survey
Target: Quiz AU name
The problem is that this button often has no effect at all (ON SOME
BROWSERS). For instance, it on IE8 but it does not work with Fire Fox
(Windows or Mac).
Chrome and Safari cannot be tested because of issue 1.
Summary:
Works with: IE8
Fails with: Firefox, Chrome (did not start), Safari (did not start)
3. Attempting to run the test a second time, results in a LMS "FATAL ERROR".
After successfully completing the test with IE8 (the only browser that
works), attempting to run the quiz for a second time, results in a LMS
"FATAL ERROR" on either IE8, Fire Fox, or Chrome.
Summary:
Works with: none
Fails with: IE8, Firefox, Chrome (did not start), Safari (did not start)
What else I have tried:
- Tested the above stated issues on several computers with the same results each time.
- Split up AU's and published a single AU at a time (one of lesson, one for quiz). Same results.
Has anyone seen this problem? Is there a solution?
I am beginning to lose confidence in Lectora producing reliable code that works across all browsers. Or perhaps it is my LMS?? OR ME??
More From sconnell
How do I display text with a variable in a 'Standard Message Window"?
April 29, 2010 Reply 0 UpvotesLectora X (Pro Suite) VS Adobe Captivate 4 for software simulation?
January 26, 2010 Reply 0 Upvotes
