Changing contents of audio - how do you control the audio cues??
October 7, 2010 12:00 AM
I am looking for a way to play four separate audio files, automatically - one after the other when the learner first enters the page AND individually controlled with buttons when the audio completes....
I have never experienced trouble doing this in the past but now it is not working when published. It works fine only in Run Mode F10.
I have tried On Done Playing... play next audio but the flash controller for the next audio does not appear....
At first, it looked promising that I could just change the content of the first player BUT in doing so, the embedded audio cues cannot work.
Anyone?
More From sconnell
How do I display text with a variable in a 'Standard Message Window"?
April 29, 2010 Reply 0 UpvotesLectora X (Pro Suite) VS Adobe Captivate 4 for software simulation?
January 26, 2010 Reply 0 Upvotes
