Process flow chart of a relatively complex Lectora template
Hello folks,
I may have many dislikes about Captivate 4 (which is the reason I switched to Lectora X for everything but software sims), but one really nice feature in Captivate 4 is the ability to generate process flow diagrams of the elearning (albeit primitive - but still useful in finding minor bugs).
My current Lectora template goes way beyond anything I did with Captivate. I am using a lot custom variables and actions but somewhere in the process I made a few mistakes.
The best way to visualize where the problems might be is to draw everything out.
The debug tool is a bit unwieldy and it made me wonder, is their a third party tool that can generate a process flow diagram (or similar) from a Lectora course?
Thank you
