FLV Audio questions
Greetings folks,
I have a bunch of questions about using audio within lessons.
I have audio for each page of my lessons and I wish to offer user control over the audio on each page.
Question 1:
Is it possible to create an inherited button to toggle the player skin on/off? If so, how can this be accomplished?
Currently, I successfully created an inherited speaker control to mute sound as follows:
Btn_speaker
....On Click
.......Action: Mute FLV Media
....Condition
.......Variable: Mute_On_Off, Relationship: Equal To, Value: 0
..UnMuteFLV
....On: Mouse Click
.......Action: Unmute FLV Media
....Condition
.......Variable: Mute_On_Off, Relationship: Equal To, Value: 1
..MuteToggle
....On: Mouse Click
....Action: Modify Variable
....Target: Mute_On_Off
....Value: 1
....Modification Type: Set Variable Contents
....Condition
....... Variable: Mute_On_Off, Relationship: Equal To, Value: 0
..........Else
............Action: Modify Variable
............Target: Mute_On_Off
............Value: 0
............Modification Type: Set Variable Contents
However, I no longer wish to simply toggle mute while the audio is playing. Rather, I want to hide/show the player skin.
Reason: I do not what to clutter the learning material with the player skin... unless the learner must re-play a portion of audio.
I mention 'inherited' because I want to minimize code or instructions. I am hoping I can set this up once at the top of an AU and reuse it on every page.
Question 2:
Is it possible to add new skins to Lectora?
The folder location is: D:Program FilesTrivantisLectora Enterprise EditionSupport FilesPlayerSkins
I added a new custom skin into this folder but the Lectora skin selection did not change. The only available selections are None, Black, Blue, Red, Silver. I replaced one of the skins with my own but it refused to work. I wonder if there is something 'special' about these Lectora skins. If I had the source fla file, I could simply modify an existing skin.
Question 3:
I am disappointed that Lectora did not include the source code for these skins. I wonder if it is possible to obtain the source code?
