Event triggers with audio
DavidS in thread: http://forum.trivantis.com/f2/new-user-adding-audio-files-9260/
said this:
>The FLV format allows you to choose the style of the
>controller on the page, plus it allows you to embed
>trigger points in the audio file which can be used to
>control other on-screen objects so it can be synched
>to the audio.
I don't get it?
I changed my inserted audio to FLV but now the Auto Properties - Events tab has a disabled pull-down menu and the Skins tab states, "Skins only supported for Flash Video/Audio"
Before I converted the audio, the Events tab was enabled but the pull-down was blank.
The Lectora X users guide is near useless as it only briefly discusses this topic and doesn't explain how to use event triggering.
Any assistance is appreciated.
