Allow selecting compatible browsers (and versions) when publishing
The file trivantis.js controls which browsers are allowed to view course content and display a fixed message when a browser does not meet its tests.
Unfortunately, this javascript is flawed in that it fails to allow certain browsers (like Opera) to view Lectora content. A simple fix (search the general forum for "Opera") will correct this problem but you will need to manually replace this .js file each time you publish!
My suggestions to Trivantis (related to the trivantis.js file)
Allow for a dynamically created trivantis.js file.....
- Allow for selecting supported browsers and versions
-- For instance, I want to disallow any browser older than IE7
- Allow for customizing the incompatibility message
- Fix the Opera browser check
- Display a warning message but allow the learner to continue to the course
