Advice on Lectora Test on a LMS
August 25, 2006 12:00 AM
Hi SirWise23 -Did you ever find a solution to the LMSCommit Error? I have a similar problem and I can't seem to find a resolution. Something is causing the Content to not communicate to the LMS. I have 11 questions. I have tried deleting questions 1 at a time to see if any one question is causing problems. I tried deteling 1 and then 2 and then 3 questions. I finally get the message to go away after deleting 4 questions. I looked to see if any of the questions had something in common, and I could find nothing.
