Resize text box automaticly for questions
June 26, 2006 12:00 AM
Here is one suggestion.You should be able to resize multiple Text boxes in one shot.Here is my problem,I have a question made. I then use that as a model for the rest of my questions. If I edit a question and change the text, and the text is larger than the size of the old box, the text box size stays the same and I have to make them longer manually. They should automatically expand for the whole question. If not, I should be able to highlight all the boxes and say "Make width of all boxes 500" or something like that.
