Question and answer Auto Fit
Usually when I am creating a test, I just use and old test as a template and change each questions instead of deleting them and creating anew one.Any time you edit a question, if you are keeping it as the same type of question, and your new question or answers are longer than the old one, the window does not automatically resize to fit them. So if I edit the text, I have to manually drag the text box to be larger to fit the new questions.Besides taking a bit more time to do, I sometimes miss it all together and doesn't realize that it's cut off until I publish it. I would love it if the text box defaulted to show all the text the way it does when you initially create a question.
