Menu box and Video/Flash
July 29, 2008 12:00 AM
On the animation add a parameter "wmode" for the name and "transparent" for the value. Then layer things as you want them in Lectora. Test it in HTML and it should work. By setting the wmode to transparent it will hide the background of your animation. If you want to keep it you can set wmode to "opaque" and still be able to layer things. Hope that helps.
