Question and answer Auto Fit
February 10, 2007 12:00 AM
Yes, we really need auto re-size text boxes -- that get smaller as well as larger. Powerpoint has a switch that you can turn on and off by text box. I do use text boxes that are much bigger than needed with a border to highlight things so don't turn it on all the time. But why not have it as a property and each new box is the same as the previous one by default. So if I need several with the switch on (or off) I don't keep having to go in and change it.Yes, we really need auto re-size text boxes -- that get smaller as well as larger. Powerpoint has a switch that you can turn on and off by text box. I do use text boxes that are much bigger than needed with a border to highlight things so don't turn it on all the time. But why not have it as a property and each new box is the same as the previous one by default. So if I need several with the switch on (or off) I don't keep having to go in and change it.
