Abilty to see correct answer without going into questions properties
September 3, 2009 12:00 AM
I think a good addition would be some type of idication on the left hand pane that shows what the correct asnwer to a question is... perhaps something as simple as an * in front of the "Choice # Button" or whatever the correct selection is. This would make it so much easier to make sure that all the correct boxes are checked for answers when developing. This would also make it easier when I import a test and am just switching some text around on questions without haveing to go into each question to pick the right answer.
