SCORM Interoperability Issues with Lectora 18
April 24, 2019 12:00 AM
Good morning Everyone,
I was finally able to get the 508 approval to my course, however, I’m running into another issue with the LMS folks. Here’s the issue:
- I created a reward token for users when they complete each lesson.
- The token page appears in a pop-up window when the user clicks on a button.
- LMS marks the course “unsuccessful” when the user closes the pop-up window and the entire course.
- The “unsuccessful” status should be incomplete.
I test it in SABA LMS 1.2
Any thoughts how to fix it?
thank you,
Discussion (2)
I'll try although I'm not yet on Lectora 18 and I don't know Saba ...
Unsuccessful / failed should mean "completed with an insufficient score". I was wondering why the status should be "incomplete" when they receive a reward for completing the course. But usually the status would not change to "completed" without an action. Do you have an action to modify "AICC_Lesson_Status" before the token page?
How did you set up the score?
Can you post a sample?
Thank you Tim. Yes, I did have AICC_Lesson_Status at the last page of the training. Thanks to your response, I could figure out the glitch. I had a test after each lesson then a final test at the end of the training. Originally, I shouldn't grade the lessons' tests, only the final test should be graded. When I reviewed the Results tab for each test, I found that I've graded lesson 1, and that's why it fails the SCORM testing because it rendered "unsuccessful" status as soon as they complete lesson 1 test.
Many thanks for your response.
