Reading Order and Skip Navigation
January 24, 2020 12:00 AM
Hi Lectora Geeks,
Could you please help me figure this out? I added in the title level a Skip Navigation link to go directly to content. In one page, the behavior of the tabs are different from the actual reading order that I set in the Title Explorer. As you see in the attached layout, the first tab goes to Skip Navi, then to button 1 and when the content is displayed, the tab should go to button 2. However, when I tab, the focus keeps bouncing back to Skip Navi after each button. I put my actual reading order in the attachment, and this is the behavior that I want the tabbing to display but it does not.
Any idea why this thing happens?
You're mixing links with button in the tab order? That's probably more than slightly tricky. Try making "Skip Navigation" also a button.
Carl: I just checked it. The Skip Navigation is actually a button and has this 2 actions:
On Page show: document.getElementById("%HTMLNAME%btn").focus();
On Mouse Click: Go to Web: #of the Content Start text block
Good point Carl, let me try it and will come back to you.
