Generating a random pool of questions and preventing randomizing again
October 22, 2009 12:00 AM
As it stands now, when you have a random test in Lectora, you can't exit in the middle of the test, and if you do, you have to start again with a totally different pool of questions.
I need to build a test, 20 questions out of a pool of 60. Once these are pulled, the user should never see a different set of questions besides these 20. Their enrollement will stay open and htose 20 questions will stay the same until the test is completed.
Has anyone ever done this before? The test would probably have to be randomized and graded without using Lectora's built in test features to do it.
