JRE Compatibility Issue?
October 21, 2005 12:00 AM
Kevin,We don't support only the MS JVM. We support all the JVMs ... but some of them work better than others ... depends on tons of factors ... but we can tell you that the exact same JVM you are having issues with works perfectly well under Mozilla, Firefox, and Opera. There are other threads in here wehere the issue is discussed ... sometimes it's the LMS ... sometimes it's the entire scenario ... but I can give you files that prove it's timing related with the browser and the JVM ...That's one of the reasons why in 2006 we give you the option of a non-Java solution (using AJAX and JavaScript).Tim
