Scorecard "Off" for fail & "on" for pass?
OK...I've figured out how to have just the "incorrect" answers displayed. If we use the customresults.zip file you mention above, all we have to do is put the following with question 1 (Trivantis is the makers of which product below?):On: ShowAction: HideTarget: Q1Text...but with the condition that...Perform if only the following is true:Variable: Question_001Relationship: is EQUAL TOValue: Lectora...and making sure the action is at the page level (as I found out the hard way that you cannot assign a "SHOW" to an object). The next step would be to hide the "my answer" variable, since again, we would only want the incorrect answers displayed onscreen. We do this by creating an action similar to the one above, but just changing the "target" information:On: ShowAction: HideTarget: A1...but with the condition that...Perform if only the following is true:Variable: Question_001Relationship: is EQUAL TOValue: LectoraThe final step would be to simply delete the "correct1" text and you're all set.Hey, I'm actually starting to get the hang of this! I still am scratching my head at how to assign a text message of "pass" or "fail" depending on the score one gets (less than a 70 they fail, 70 or above they pass) however. Ideally, I'd like to have the score display on a specially branded page depending on whether they pass or fail - that would be great. I guess a workaround could be where, if they fail, a simple text message appears at bottom of screen which I could then hyperlink to a specially-branded page. Any ideas?Thanks,Kevin
