JRE Compatibility Issue?
A friend of mine who works for a fortune 100 company informed me the following:"PLUS since you use Publisher or Lectora, their applet only supports MS JVM."Is this true? We're having issues with some machines in IE 6.0 where most people are able to load and complete the course no problem, but others (including myself), once we click the "OK" button on a scorecard to close it after completing a quiz, the scorecard disappears as it should, but the course is permanently 'frozen'. The only way to exit is to use Ctrl + Alt + Del.Other threads I've read in here says that the Sun JRE is okay if it's v1.3 or earlier. Anyway, does this sound to you like a JRE issue? Does Lectora/Publisher only support MS JVM?Many thanks -KevinEdited By: kstagg on 38645.6688425926
