Using a window to launch a launch pg
August 31, 2005 12:00 AM
SBelzer...Thanks for your quick reply. Unfortunately, I'm still confused. So, using the code above, if you wanted your window to be sized at 750 X 500, what would you be placing in the Custom HTML field?Thanks again -Kevin
