Scorecard "Off" for fail & "on" for pass?
July 19, 2005 12:00 AM
Currently, Lectora displays the full results whether the student passes or fails. In order to do this, you will need to create a custom test results page. This can be done in a similar way to the custom feedback examples/posts mentioned in the forum.You can create your own custom results page by using conditional actions that look at the question answer selected on the page after the test. Here is an example on how to do this: 2004-08-12_084520_customresults.zipIf they pass, take them to page with the question/answer info and if they fail take them to a different page that does not give away the answers.
