Position of cursor in entry field
March 28, 2008 12:00 AM
Tip 14 in Vol 2. of my Tips, Techniques, and Secrets (click below)To suppress the borders on an either a Form Entry field or a Fill in the Blank question, create an HTML object containing:This works only when published to HTML.See the discussion in the last couple of days on Appending variables. Now that you know how to suppress the borders, maybe you can just put a text box next to it with ".00". Putting the commas in will be tough if you have to do it.
