Position of cursor in entry field
March 28, 2008 12:00 AM
I can work with examples that are less than $1,000, so I can avoid the comma problem.Thanks for the pointer, Ben. I'll go looking into that. I just found out that it's quite possible that live data will not be in whole numbers, but for the purposes of the simulation, I can restrict the data to whole numbers and not worry about the decimal. Kevin
