Jaws issue with True/False question
July 4, 2022 12:00 AM
Hello everyone,
I have built a True/False question and when I run through JAWS and Tab I am not able to select False option. I can only select True option.
Can somebody please help?
Thanks
Soni
Discussion (2)
@ssoni to move to different radio buttons in a group (the true and false radio buttons behave as if are in the same group, same as with MC questions) use the 'A' key. The arrow key will also work but needs to be pressed twice
I worked out why it was happening. Because I used custom radio buttons. For JAWS to be able to read both True and False you have to leave the radio buttons as default.
Looks like there’s bug in Lectora 21 that if you use custom radio or check boxes it just doesn’t work.
