Adjust colouring for matching questions
April 21, 2021 12:00 AM
Hello again,
I've been playing CSS to adjust the colour of the fieldset background-color but no success. Is there a quick CSS that I can apply or location in the application to modify them module wide?
Below is the devtools screenshot and one half of the question showing the blue (#0000ff) colouring that I'd like to change.
Cheers and thank you.
Andrew
Solutions (2)
And... I answered my own question... For those wanting to figure it out, you can do it with the following setting under the EDIT QUESTION popup window.
fieldset
border: solid 1px #080808;
background-color:yellow !important;
fieldset
@nmaharaj thanks for the answer in CSS. This will definitely help me down the road! Cheers!
