Test Buttons Not APPEARING - it's crazy!
August 1, 2008 12:00 AM
Laura, Trivantis, Forum Members et allI am officially done with JavaScript...Okay, not that bad. I thank you so much for this. I just had the same problem on a separate issue. I do not know why these funky characters are appearing in my responses unless I might have recently did a COPY / PASTE ordeal when creating these.I guess if that is the case, I need to ensure I convert all text to a .txt file first then copy and paste and be sure to CHECK for erronous characters.Thanks for looking into this. I need to remember that these extra characters have caused me much grief in the past days and to check more thoroughly for them. I looked at every other option - but without result.Thanks again.Moral of the Story:Copy and Paste = BAD!
