AICC_TIME* Usage... How to use - HELP
There are so many different variables... apparently I have not been using one which would have come in handy, and that is the AICC_TIME variable... I did not realize this until I went to run Usage stats on the courses I authored, and published to Learn.com.Through investigation, I determined that the AICC_TIME variable is what is needed to return a cumulative time back to the LMS reporting...Can any user out here in ForumLand assist me in the proper usage and placement of such a variable?Any help is soooo appreciated.Thanks in advance.
