AICC_TIME* Usage... How to use - HELP
January 31, 2007 12:00 AM
Thanks Sir...Ironically, I am not trying to do anything other than the variables intended function: View reporting data which shows a uses total time in a lesson.However, when I run a report from Learn.com, this variable field is displaying as blank, at least for the few courses I authored, as well as some others which I lease from them. However, on other occasions, the field is populated with times - so the question remains for me, why and how are some getting populated and others (such as mine) not getting populated.That is what brought me to bring it before the forum.You have been very enlightening... I am fearful that I will have to persue this with Learn.com and see if they have underlying requirements for the execution of the variable before they will display the data.Thanks again
