AICC_TIME* Usage... How to use - HELP
No experience with it BUT here are some considerations:1. Check with Trivantis and Learn.com directly. support@trivantis.com and Learn.com unknown.2. Ask what happens if your course is restarted. Does the variable add the current duration to the previous one?3. If you have to set the variable yourself, how do you get the previous value when the course is restarted?4. What do you need to do to handle the situation where someone went home at night and left the course running? Do you need to have your own time out routine?I can help re. calculating the time on the Lectora end and the timeout issue but have no idea re. the LMS.
