png images not transparent in IE6
October 22, 2007 12:00 AM
Hello,Unfortunately the solutions posted here have not worked for me yet. I have however managed to come across a solution to the png transparency issue that seems to work (at least so far). It is based on viewing the source code from the site Hemingway mentioned (http://homepage.ntlworld.com/bobosola/) , and copying and pasting the information I needed. Here are the three steps:1) At the title level add an "External HTML Object"2) For "Object Type" select "Other"3) Add the italicized code below into the "Custom HTML" input box (literally copy and paste everything), select "OK" and you are ready to preview!Edited By: cmh1280 on 2008-1-3 15:48:24
