Flash Navigation sample won.t run
September 20, 2007 12:00 AM
You're right Mark, the version published to the web worked and when I changed the setting to always allow for the local folder this worked. What I'm concerned about is if I distribute a package in html format on a CD, would I have to give users instructions on changing these settings or is there a way of programming this in so it is done automatically.ThanksNick
