png images not transparent in IE6
October 22, 2007 12:00 AM
Yes, if you are getting a grey box around your images, it's the same IE6 bug. As far as I know this problem only occurs with PNG-24 format in IE6 and maybe previous versions as well.This link explains common myths about PNGs a bit and links to several work arounds. Can't say they'll work, but give them a shot: http://css-tricks.com/misconceptions-about-png/ Edited By: Gwempz on 2008-1-3 16:53:36
