Flash Navigation sample won.t run
Nick - it sounds like it's an issue of running it locally. When published to the web (or to an LMS) you shouldn't be getting those errors. For some reason IE7 has tight security settings for things run from a local comptuer as opposed to an internet zone. Go here and try this:http://www.sharpmedia.com/flashnav/index.htmlThis is the exact same stuff, only posted to a webserver. If the controls work here, then the problem is with your local settings (meaning that although you have problems locally, the end user won't get those warning).One thing you might try is to go here: http://www.macromedia.com/support/documentation/en/flashplay er/help/settings_manager04.html and make sure "Always allow" is checked (note that this is just so things will run locally - your end users won't have to do this). Let me know how that goes.
