Flash Navigation sample won.t run
You could try setting a parameter on your flash movie via the parameters tab in lectora. For the name put "allowScriptAccess" and the value put "sameDomain" or your could also put "always" as the value and see if that does anything. If that doesn't work I'd be happy to look at your .fla file to see if I can find something that would keep it from working.Edited By: Hemingway on 2007-9-20 17:15:34
