How to display (Show) Variable Contents
An empty text block will inherit the text properties from the the title or for that page. What you can do if you don't want to change those settings is add some text to the text block, select the font, color, etc., have the text block not initially visible and then below the action on the page that is changing the contents, add another that states on show, show, text block and delay it 0.1 seconds. That way the end user won't see the text you initially place in the text block. Make sure you place both actions at the page level rather than on the text block itself. An empty text block will inherit the text properties from the the title or for that page. What you can do if you don't want to change those settings is add some text to the text block, select the font, color, etc., have the text block not initially visible and then below the action on the page that is changing the contents, add another that states on show, show, text block and delay it 0.1 seconds. That way the end user won't see the text you initially place in the text block. Make sure you place both actions at the page level rather than on the text block itself.
