How to determine RESERVED Variable Values
June 27, 2008 12:00 AM
Thanks Teco...That is what I was alluding, but need (okay - desired) just a little more clarification. Does a T/F question retain a correct value of "True" or "T" or "1" or "0", you see where I am coming from? Without knowing exactly how Lectora stores the correct answer for a T/F and Multiple Choice its a little difficult.I think you are soooo on the right track, but I'd just like the exact specifics to clarify exactly. Also, are the values to be used, in uppercase, lowercase, or does it not matter?Thanks for your help.
