How to determine RESERVED Variable Values
While I was reviewing a recent post to not allowing a user to advance in a test until they got the answer correct, I knew the solution would involve a few hidden images and checking of Reserved Variable values to the test questions.So I located my reserved variables for my quiz: Question_0001 etc.My question is this, how can we determine what the Correct/Incorrect variables are for that/those question(s)? In the Variable Manager, it shows the Variable Name: Question_0001, Variable Type: Question, and Question: Question 1. I can look at the question and tell that the type is True/False or Multiple Choice. And I can tell from the question which is the correct answer. But, how can I tell what the correct value will be in the Question Variable that one value which tells the LMS, the item is CORRECT (assumed that all other variable values would indicate an INCORRECT answer).Is it not true that if we were able to identify this variable, the we can put highlights over answers that were wrong or right in a test and even block the NEXT button until the correct answer was entered correctly?Am I making too much of this, is this info at my fingertips and I am missing it?Note: My inquiry is in response to a possible solution to the recently posted topic: Avoid pop up for Question feedback page Edited By: whorah on 2008-6-27 11:50:51
